Fitting a stainless steel splashback
6 Nov 2011
Hertfordshire
I have a stainless steel splashback to fit to a painted wall and don't want to use screws.
Are any adhesives or silicone suitable?
It's 600mm x 750mm and 1.2mm thick, so quite heavy
Does the bottom edge rest on a work top or something similar?
Adhesives are fine so long as the wall (and the splashback) are dead flat.....if they arent I'd still go for screw fixings, personally.
John :)
That's one hell of a kitchen you are fitting this in! I assume its split into sections of up to 5metres?
For glass splashbacks I have used silicone as recommended by the supplier.
Usually they need no support once in place as the silicone grips well. Where I have been a little unsure I have used a scrap of wood screwed into the wall above to hold it in place for a few hours.
If the wall isn't 100% level, then just apply thicker silicone to make up the difference. This works for a couple of mm.
Original post has now been edited, originally said 75m.
Nice of the OP to not mention the edit.
Very sorry - I did indeed edit the measurement.
Thanks for the advice, looks like lots of people recommend silicone.
I don't want to rely on the upstand for support but can do that - I need to run a silicone need between the splashback and extractor so that'll help too.
If I'm using silicone I'll put a sheet of ply against it then wedge that with some lengths of timber to hold it while it goes off.
Thanks for the advice.
All done.
Used a couple of wedges on top of the upstand to even-out the gap between the upstand, splashback and extractor fan. I put a load of silicone in the back splashback, applied to the wall then rested a length of timber to hold it.
It's not fallen off yet.
