fitting a wire system to a lighting circuit not ring main?
28 Feb 2008
Plymouth
Hi, we are trying to fit a wire cable lighting system. We've put the 12v transformer under the floor boards, and weve put a 3amp fuse between the between the lighting switch and the transformer. It worked for a few hours then blew the consumer unit. I am wondering if it should be wired into the ring main instead as it came with a 3 pin plug. What do you think? And if so, can I still use my lighting switch on the wall? Should I just uprate my fuse?
Paulmann 12V Wire System Glass 5 x 20W G4 Chrome & Satin Effect LINK: ( http://www.diy.com/diy/jsp/bq/nav/n...210021058979&isSearch=false&selected=products )
Thank you, but what do you recommend I do? Any ideas?
Anyone else ever tried a 12v transformer on a lighting ring?
what did this "trip" have printed on it?
and yes transformers on lighting circuits are not new
TIP guess what
this button is for
Sorry, im not explaining myself well. I just mean the switch that flips down on the consumer unit when there is a short circuit or something. It was the one for the downstairs lighting at the back of the house and when I switched it back it was fine but the lights arent working. Ive not replace the 3amp fuse which is inline yet. Its just happened today and Ive no replacements. thanks for this help.
i dont know if the 3 pin plug on the device had a 3amp fuse in it: im wondering if we should upgrade the fuse thats between the transformer and switch, but the lighting circuit is 3amp on the consumer unit i think.
still not tried using the
button then?
it may be one of the lamps faied taking out the mcb
get a new fuse of the same rating, maplin will have them
