That is, indeed, what I wrote - but I'm afraid I don't understand your point. In case it wasn't obvious, what I (and I presume also the OP) meant was a flex outlet plate inside the bathroom and an FCU outside the bathroom. The reason I said that it was 'probably even better' (than having the FCU itself in the bathroom) was that, particularly if it's a switched FCU, it would probably be better for it to be out of the steamy atmosphere of a bathroom. However, as I said, your point about movement of the flex where it leaves the accessory is true whether the accessory within the bathroom is an outlet plate or an FCU. I guess I'm probably just being dim - could you possibly clarify your point?that was your quoteIndeed - that was obviously the point I was making. The OP's plan to use a flex outlet plate with the FCU outside of the bathroom is probably even better.
Kind Regards, John
