Fitting bath today. -what sealants/hybrids to use??
5 Jan 2009
Hi all.
Ripping out knackered bath today. It's up against cheap cladding/leaking from shower, not supported.
I intend to fit new on on 2x1 roofing battens or even 4x2 (I have plenty of both).
All videos I have seen they are not using standard silicone anymore.
It's all BT1 or CT1, OB1 etc.
What do u recommend for first fix seal onto the battens? A suitable clear hybrid??
Then once that has cured what shall I use as final seal that is visible?
I have always used Dow Corning white or have things moved on?
I can see the advantage of using a hybrid on battens as it's will also act as a 'grip'.
Also will be using a smear of LSX on overflow waste.
All iitems need to be Screwfix stock.
Cheers
I think that everyone uses polymer adhesives now just because they are there and available. Me, I think it's a bit of an overkill, I've used silicone sealant for as long as, without any issues, it's a little more flexible and has a bit more give when it comes to acrylic baths so I don't see any need to change.
Silicone adhesives cure to a much harder rubber and are a bit less forgiving, great as a wet grab or semi permanent jointing medium. Though I have seen them pull the top off of plasterboard when flexed to much. Just my personal preference tho.
