Fitting blinds to this awkward bay window
  • Thread starter Deleted member 281264
  • Start date
D
I need to fid some blinds to this 5 sided bay window, but the reccess is not thick enough for most blinds and then there is architrave above.
Anyone have any suggestions?
If it were me I think I'd consider building a pelmet on the face of the 'architrave' to house the blinds, the face of the pelmet running paralell with the architrave.
Perfect fit blinds?
Quite a few options/styles
My windows are flush casement windows, unfortunately perfect fit blinds will not work
One fitter suggested drilling into the frame and gave me a ridiculous quote, so I'd rather do it myself
thanks, good suggestion what would you use for the pelmet?
Bendy plywood or similar (its a thing, google it). It's possible to make your own to save buying the ready made stuff if you put a series of cuts in the rear of the board, you would need access to a table or mitre saw or similar though. Might be worth considering.
You would need to keep the distance between the new pelmet and the architrave to a minimum to reduce any twisting under the weight of the blinds.
What type of blinds are you fixing?
Roller, Venetian, vertical, Roman?
Or 3mm MDF is quite a popular choice for this by all accounts, after googling, the whole thing ideally made up and then hung on the wall rather than making it insitu.
Thanks, I was thinking MDF might be better
I'm still a little confused about how to do it best and make it look good. Where and how would you suggest is the best way to attach it?
