fitting bosh ovens
1 Jul 2011
Lanarkshire
Hi just built new standard size larder housing unit and want to install 2 appliances.
I have a single bosh series 6 combination oven and a series 6 single oven.
I have put shelf in at appropriate height for 2 ovens , but I can't find any info on fitting them . Does one just sit ontop of the other or does a shelf attache to unit to sit top one on.
I also need to fit heat deflectors. but what type ect.
Alec
Alec
You need two shelves, one for each of the ovens.
Each oven then slides onto its own shelf and there are securing screws on front face of ovens (behind oven door) to secure them in place.
sfk
I fitted the shelf for the upper oven with brackets once the rest was fitted. It's always been a pain to get that second shelf in the perfect position so that there isn't a gap between appliances, but the door of the top one can actually open.
The current kitchen they didn't fit perfectly anyway and so a 25mm filler was needed above.
