Why do you think that might be necessary?Should the 40rcd be uprated to a higher one.
I thought you said you were going to use 32A?Its cause the instructions say to use 16amp protection.
The most recent discussion here: https://www.diynot.com/diy/threads/smart-meters.479120/Smart meter aint final and can b cancelled. Only wanted it for the energy usage display and free leccy on a Sunday/Saturday
Why isn't the electrician who is going to do the work making his own decisions?Had a look at the wylex cu. It has a 6 mcb and 40rcd so just need to put a 32mcb in for oven. Should the 40rcd be uprated to a higher one.
But it's not, is it? If it isn't already complete, with a protective device, then it isn't a circuit.Yes it's a new circuit that's connected but not commissioned yet.
Please get an electrician.Incase anything else got added in furure but highly doubt it. I found a wylex 32 mcb in screw fix for under a fiver. Im sure I have a 32mcb in house somewhere but its a diff manufacturer mkm I think . Would another breaker fit a wylex box
Let's suppose you have a Toyota car. The brake calliper has seized. Somewhere in your garage you have a brake calliper from a Mini, would it be a sensible plan to try and fit that??m sure I have a 32mcb in house somewhere but its a diff manufacturer mkm I think . Would another breaker fit a wylex box
In other words "no".Let's suppose you have a Toyota car. The brake calliper has seized. Somewhere in your garage you have a brake calliper from a Mini, would it be a sensible plan to try and fit that??
