Last week my mothers built in cooker oven kept tripping the RCD when switched on at the wall. I removed the oven and the melamine shelf it had been sat on had been burnt through and the cable about 6 inches down from where wired into the oven had been burnt back to the copper. It looked like the oven was sitting on the wire.
I replaced the melamine shelf with same thickness tongue and groove flooring, cut the cable back and put an oven outlet box on the wall behind the oven and rewired the oven making sure the cable was well away from the shelf / oven.
The first time she cooked with it, itwas fine. Today the kitchen was filled with the smell of burning wood. The shelf the cooker sits on was warm around the edges and in the middle where the previous shelf had burnt though was too hot to touch.
At the moment I am letting the oven cool before pulling out to check the shelf.
The only thing I can think of is to once cooled switch just the top oven on for a while to see if the shelf gets warm, if it does not I can only assume the insulation on the base of the bottom oven has failed and that if it still warms up with just the top oven on that it is some kind of electrical fault, either way it looks like a new cooker.
Any thoughts or ideas to avoid this would be most welcomed indeed
Many thanks in advance
A
A
