There is no problem.It is settled only in the sense that neither you nor JW2 are prepared to recognise the problem.
I disagree. We are talking about connecting a conductor to an RCBO.Everything you have said can also be said about mixing and matching different makes of MCB in a CU, and yet this is always deprecated because of the type testing issue.
If you like I shall do away with the busbar and use cables to connect all the RCBOs. No pictures so not allowed?
Would you like to specify what you think the problem might be?
Poor connection? Heat? Lack of picture?
What about a consumer unit with Main Switch and three RCCBs? Not allowed because no picture available?The photograph above shows a configuration approved by the maker. You are advocating doing something which is not approved.
You say "no matter how correct you(we) may be" so it is just the lack of picture which concerns you.Neither you nor JW2 are prepared to accept the fact that no matter how certain you are that it will be fine, no matter how correct you are, and no matter how tiresome you find an apparent prohibition on you thinking for yourselves, you may not tell people to connect cables to the busbar of a CU in a way which the maker does not support.
Much like something not shown in Appendix 15 which I believe you recently did agree with.
Answered above.If there's nothing wrong, then there is no harm in asking, for they will surely say it will be OK.
If you are worried about asking because you are worried that if you do they will say it is not OK then that ought to tell you that you should not be suggesting it.
You are prioritising your "right" to do something which is not approved because you know it will be OK and therefore what you decide can be done may be done, no matter what the maker of the equipment thinks about it.
