    Dismiss Notice
fitting external door frame
Discussion in 'Building' started by theDIYkid, 18 Aug 2020.
  1. theDIYkid
    theDIYkid
    27 Nov 2013
    292
    Thanks Received:
    2
    Yorkshire
    Country:
    Hi experts
    When fitting an external hardwood door frame how far inside the outer wall does it go in to the gap? assuming it doesnt sit flush with the external skin outside. And the bottom sill does this float over the edge of the floor base.
  2. ted456
    ted456
    11 Mar 2020
    179
    Thanks Received:
    46
    shrewsbury
    Country:
    Its recom that all frames are set-back from the face of the building by 75mm.
    Frame openings in masonry can vary quite a bit taking into account any cavities, cavity closers, DPC's and how the masonry has been constructed.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. 23vc
    23vc
    17 Apr 2015
    2,455
    Thanks Received:
    390
    Warwickshire
    Country:
    Set it back as far as poss so you can still fix it to the external skin. So maybe 30mm or so. Yes the cill protrudes out over what is normally the DPC course.
    • Thanks Thanks x 1
  5. ^woody^
    ^woody^
    3 Sep 2006
    32,768
    Thanks Received:
    4,428
    West Mids
    Country:
    Frames should cover the vDPC by about 10-20mm. That dictates the set back.
    The further it is set back, the greater the weather protection of the frame and the joint.
    • Thanks Thanks x 1
  6. Sponsored Links
  7. theDIYkid
    theDIYkid
    27 Nov 2013
    292
    Thanks Received:
    2
    Yorkshire
    Country:
    Thanks for all replies this helps I think I can go in 50mm as the external course is yorkshire stone.
    I was thinking of attaching the sill on top of a line of DPC then 5-1 sand and cement bed and no need for glue, is that ok?
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
