Hi All
So, panels and posts rotten along rear boundary. 4 1/2 6ft wide panels. Post spikes in ground solid enough.
Not done this before, but found posts (3”) and some closed board fencing we like. However, is there a way of securing the panels without lifting all the way up to the top U Clip? The other side is against overgrowth and 2 sheds, so we will have the good side! But I cannot access from the other side to screw to post, hence clips. However, the panels are too heavy to lift and slot in.
Is there not some kind of U Clip where one side hinges to allow the panel to be fitted, they push back and screwed? Sorry if not clear! There must be a solution not requiring the heavy panels being lifted?
Sorry for the daft question!
Many thanks.
Many thanks.
