- Joined
- 22 Oct 2007
- Messages
- 131
- Reaction score
- 0
- Country
I've got an old brick wall bordering my garden that ranges from 500mm to 700mm in height (garden slopes gently).
I'm want to install a fence along the top of the wall using bolt down 3" metposts, the fence will be built using a 1830*1200mm lap panel, then a half lap/half trellis panel, another full lap panel and then finally another half lap/half trellis panel, the plan being our neighbour will be happy that we arn't blocking all her light The highest end of the wall will have a narrow panel and a gate which will help strengthen the end of the fence.
My main concern is how the wall will cope...if I use standard expanding bolts, will I loose the top row of bricks as soon as we have a storm? I'm tempted to drop threaded bar into holes around 300mm deep and then resin them in the spread the side loads through several courses of bricks. The wall is old but I don't really want to take the approach other neighbours have and use rusty angle iron nailed into the brickwork to support the fenceposts. Alternatively, are expanding bolts available in longer lengths?
Finally, the wall nearest the house is damp and I want to install some coping stones along the top. This section will only have a couple of 400mm trellis panels as it is higher than the rest of the wall. Is it possible to drill through coping stones with a masonry bit to fit a central metpost to support the two panels or will it crack/crumble?
Thanks for any help
Thanks for any help
