I have an ongoing pressure loss problem with my Worcester Bosch Oil Fired Combi. I want to install isolation valves on the 22mm flow and return pipes, so I can check whether the leak is in the radiator circuit or the boiler.
These pipes are quite tight to a wall and rigid, and I think when I cut them they will be hard to move around/up/down so I can fit a compression fitting valve.
Is there a type of valve that will be easier to install in these circumstances?
