Fitting larger diameter down lighters in existing holes.
10 Feb 2009
Bristol
I'm swapping some existing fixed down lighters for moveable ones. The hole needs to be bigger for the new lamp but I cant use a holesaw as there is already a hole there.
Is there simple way to centre a hole saw over an existing hole?
Regards,
Jon
either stack the holesaws ( ie one inside the other on the same arbour ), or screw a piece of wood over the back of the hole and re-drill the pilot..
the later usually ends up with you having to patch the 2 screw holes but a bit of filler does that job nicely..
There's no simpler way than marking the new diameter on the ceiling and using a simple plasterboard-padsaw. It's not as if you have hundreds to do, is it?
Lucia.
Cut a hole with the new holesaw in a bit of thin plywood, place over existing hole and drill with care, done it a fair few times to good effect, but this technique does take a bit of skill.
