    Dismiss Notice
Fitting Monobloc Taps. You've Been Doing It Wrong.
Discussion in 'Plumbing and Central Heating' started by ReganAndCarter, 5 Oct 2021.
  1. ReganAndCarter
    ReganAndCarter
    13 Sep 2010
    4,005
    Thanks Received:
    391
    Moravia, CZ
    Country:
    Czech Republic
    Great tip.
    • Thanks Thanks x 1
    • Like Like x 1
  2. Sponsored Links
  3. fixitflav
    fixitflav
    20 Mar 2018
    1,230
    Thanks Received:
    139
    Stoke-on-Trent
    Country:
    Which bit? The only good idea I can see is threading the horse-shoe washer through the hole, instead of struggling under the sink.
    When I only had an ordinary socket set to hand, to get the nut near enough to the end of the threaded rod to get a socket on, I've used a distance piece. 1/4" NB steel pipe is just the right ID for an M8 rod. Since then I've got a box spanner, which gets round it.
  4. ReganAndCarter
    ReganAndCarter
    13 Sep 2010
    4,005
    Thanks Received:
    391
    Moravia, CZ
    Country:
    Czech Republic
    (y)
  5. John the plumber
    John the plumber
    15 Oct 2020
    1,353
    Thanks Received:
    53
    Cornwall
    Country:
    Have you not already been doing that on some installs?
    Started doing that about 5 years ago on some tough installs (y)
  6. opps
    opps
    16 Jun 2006
    5,153
    Thanks Received:
    816
    London
    Country:
    I must admit that I had never thought of doing that.
    • Thanks Thanks x 1
    • Like Like x 1
  7. Sponsored Links
  8. RrogerD
    RrogerD
    8 Jun 2013
    201
    Thanks Received:
    4
    Gloucestershire
    Country:
    So my question is, where is his rubber o ring seal under the tap? It appears to me that he has threaded this down to below the sink.
    Not what I was told by the informative persons on this forum a couple of weeks ago :-/
  9. fixitflav
    fixitflav
    20 Mar 2018
    1,230
    Thanks Received:
    139
    Stoke-on-Trent
    Country:
    The method in the video obviously wouldn't work with your tap, as the plastic spreader won't go through the hole.
    I think the order in #3 of the earlier thread is correct, the O-ring above the sink. If it were below it would be up against the rubber washer in the spreader, which doesn't seem right. Have you fitted it yet, and is it OK?
  10. RrogerD
    RrogerD
    8 Jun 2013
    201
    Thanks Received:
    4
    Gloucestershire
    Country:
    A-ha, yes it's all fitted. I used the o ring above and the plastic spreader plate below. I can't say if it all ok as I'm still waiting for the plumber to connect up the mains water. Looks good though! And pretty solid.
    Thanks for asking.
  11. fixitflav
    fixitflav
    20 Mar 2018
    1,230
    Thanks Received:
    139
    Stoke-on-Trent
    Country:
    Well done! Good luck.
    • Thanks Thanks x 1
Loading...
Share This Page
