HI FRANNY, YES YOU COULD FIT A WIRELESS PROGRAMMER BUT YOU WILL STILL NEED A COMPITENT PERSON TO WIRE THE UNIT INTO THE BOILER ITSELF INCLUDING A LIVE AND NEUTRAL.
EACH SITUATION IS DIFFERENT BUT IT MAY BE CHEAPER TO INSTALL A STANDARD WIRED PROGRAMMER BY RUNNING A FOUR CORE AND EARTH CABLE FROM THE BOILER TO YOUR CHOSEN LOCATION.
HAVE YOU GOT A SEPARATE ROOM STAT WIRED TO THE BOILER IF SO THERES NO NEED TO GO FOR A PROGRAMMABLE ROOM STAT AS THEY CAN BE CONFUSING TO OPERATE.
HOPE THIS HELPS.
NEAL.
