I am redoing our bathroom and need to square the walls up. in the past it has had chipboard put on walls about two thirds up to to level the walls off where tiles were fitted on the bottom third of the wall. I have knocked a wall down to make a larger room and now need to level the walls for tiling. I was going to fit moisture proof plasterboard.
To allow me to fit a 700mm shower tray I need to keep as close to the bricks as possible on one wall as the window is in the way. whats the best way to fit the palsterbaord to the brick? I cant batten as it will be to deep. Can I dot and Dab with plasterbaord fix or could I foam it?
