Fitting Polycarbonate sheet to exsisting shed roof
15 Nov 2004
I would like to create some more light in my garage ,and was toying with the idea of putting a Polycarbonate sheet into the exsisting roof but i have not got a clue about the best way of doing it . The roof is covered with the usual felt and is tongue and groove but i need to make it waterproof obviously. Is there any kits you can buy or is this just not practical to do and course more problems than its worth regards Edd.
It is a simple job to do, merely removing a section of the roof from the top and inserting the polycarbonate, Wicks sell all the bits you need and have some "how to" sheets. Make sure you use a lead strip at the top to avoid any water getting in.
juwelkeeper how did your roof turn out? I want to do the same but worried how to seal the ridge /point part of the roof. What worked for you?
Some of the companies that sell polycarbonate will put together a kit to suit your shed which will include the ridge, and deliver it together. You will need a timber under each seam, and enough to screw the sheets down. You can get a galvanised thing like a small joist hanger to add extras if necessary. IIRC mine are at 600mm centres.
