Hi Guys,
I'm about to fit a sink into solid oak worktops and have a couple of questions.
The sink (astracast granite) comes with pre-fitted securing clips which I spring out and tighten up after the sink is lowered into place.
Trouble is, a number of the clips are inaccessible due to ...
2 sitting behind the back rail in the schreiber base cabinet and 2 are in the "dead area" formed by the corner.
The only way I can see to get to the corner clips is to cut away a piece of the hidden end wall so I can get my hand in ... Is this the norm?
The two clips in the main sink carcass behind the back rail are a little confusing though as all sinks are pretty much the same and I can't see how I can get to these without cutting into the back of the unit which will obviously show ... Any ideas?
One last question ... Is there any preference to where the sink should be positioned between the front and back of the worktop? I was aiming for central with maybe a slight tendancy towards the back but grateful for any advice.
Thanks loads.
Thanks loads.
