    Dismiss Notice
fitting washing machine how tight connections
Discussion in 'Plumbing and Central Heating' started by Xanderharris1, 1 Aug 2016.
  1. Xanderharris1
    Xanderharris1
    28 Oct 2014
    68
    Thanks Received:
    Leeds
    Country:
    When tightening the connections on a washing machine is hand tight all that is required. Or is say half a turn with a pair or grips needed?
  2. Sponsored Links
  3. stardanny
    stardanny
    14 Nov 2007
    1,657
    Thanks Received:
    254
    Buckinghamshire
    Country:
    If it is the washing machine hose pipe, hand tight is all need.
    Daniel.
    • Thanks Thanks x 1
  4. Xanderharris1
    Xanderharris1
    28 Oct 2014
    68
    Thanks Received:
    Leeds
    Country:
    Yes the hose pipe with the rubber washer. Is this because if you tighten with grips you can split the washer? Also if putting the drain in to a stand pipe do you need to put anything on it to keep it in the stand put when discharging. And if going on to a uni corn part of a sink trap do you need to use a jubilee clip to hold it on? Thanks
  5. stardanny
    stardanny
    14 Nov 2007
    1,657
    Thanks Received:
    254
    Buckinghamshire
    Country:
    Yes, tighting with grip may spilt the plastic hose nut as well. Hand tight is usually enough.
    No, if you put drain hose into stand, it will not come out.
    Yes, jubilee clip is a must, as if drain hose get soften by hot water, it may loose itself off.
    Daniel.
    • Thanks Thanks x 1
  6. Xanderharris1
    Xanderharris1
    28 Oct 2014
    68
    Thanks Received:
    Leeds
    Country:
    Thanks its a washer dryer do these usualy plumb in the same as washing machines? Just a cold feed and a drain?
  7. stardanny
    stardanny
    14 Nov 2007
    1,657
    Thanks Received:
    254
    Buckinghamshire
    Country:
    Yep
    • Thanks Thanks x 1
  8. garygooner
    garygooner
    19 Jan 2012
    12
    Thanks Received:
    London
    Country:
    I would always tighten a little more with grips , ive hsd to go to loads of leaks where delivery drivers have installed
  9. durhamplumber
    durhamplumber
    23 May 2010
    12,107
    Thanks Received:
    538
    Durham
    Country:
    I agree....
    tweek with grips..
  10. Sponsored Links
  11. Xanderharris1
    Xanderharris1
    28 Oct 2014
    68
    Thanks Received:
    Leeds
    Country:
    Does the dryer part not need a separate waste?
  12. Xanderharris1
    Xanderharris1
    28 Oct 2014
    68
    Thanks Received:
    Leeds
    Country:
    How much more? 1/4 turn or even less than this?
  13. Madrab
    Madrab
    4 Oct 2012
    7,060
    Thanks Received:
    1,913
    East Renfrewshire
    Country:
    Plastic on metal with a rubber washer - I only do as tight as I can get with my hand. With a new install I always say to the customer, pull out the machine in a month and tighten it again once the washer has bed in. Too tight and it'll be a pig to come off later too with a deformed washer.
    If someone calls me saying they have a leak with their machine hose i just tell them to tighten it and see if that stops it, 95% of the time that's all it needs and no need to go out on a call and charge them for something as daft as that and I usually then get the call when it's something significant.
  14. durhamplumber
    durhamplumber
    23 May 2010
    12,107
    Thanks Received:
    538
    Durham
    Country:
    hand tight......it's gonna leak soon.99% of the time.
  15. Xanderharris1
    Xanderharris1
    28 Oct 2014
    68
    Thanks Received:
    Leeds
    Country:
    Ur saying if you hand tight it will eventual leak?
  16. stardanny
    stardanny
    14 Nov 2007
    1,657
    Thanks Received:
    254
    Buckinghamshire
    Country:
    Ignore what other say, hand tight and it will be fine.
    Daniel.
  17. Xanderharris1
    Xanderharris1
    28 Oct 2014
    68
    Thanks Received:
    Leeds
    Country:
    When you tigthen the.female end.of a flexi on to a 1/2 male iron or iso valve you go more than hand tight, is this not the same?
Loading...
Share This Page
