fixing a worktop
28 Oct 2008
Hampshire
Hi there I have a bit of worktop 60mm think and 600mm by 600mm just to go over out tumble dryer now what would be the best way to fix it to the wall bearing in mind its the same size as the tumble dryer thx
Thunder bolt a piece of angle iron to the wall and screw up through into the work top from below.
This company.............
http://www.corusgroup.com/en/ will supply you the steel. Thunder bolts and wood screws are available from most hardware retailers.
Rebate the work top to recess the angle if you want the lower side to remain flush to facilitate the installation and easy fitment of the tumble dryer.
:D
