I want to fix a wooden batten to the wall above a large window to attach a curtain rail to. The batten will be 280mm long. Is it best to use nails, and if so what kind, or screws? If I screw it should I use wall plugs? If I drill a hole through the batten and into the wall should the wall plugs extend through the batten too or should I try to push it through the wood so it is only in the wall? I dont want to use any adhesives?
Thanks for any advice.
