I have recently replaced the gatepost and gate etc.
75x75 post next to a wall
I was recommended to use these
Thunderbolt Hex Head Passivated Zinc/Yellow 10mm (M10) x 150mm
http://www.alsfordtimber.com/tools-...ivated-zinc-yellow-10mm-m10-x-150mm-8372.html
and to use a 10mm drill
anyway, they all bolted back into the wall OK
and I had a bigger hole in the timber so the timber part was about 50mm ish
now they have just pulled out the wall
height of post about 2.1m
4 bolts used
so how do i fix this now
use something like this
http://www.screwfix.com/p/fischer-fsa-sleeve-anchors-10-x-95mm-m10-pack-of-20/66010
Or some form of plug around the existing bolt, paper
I have a wall now with 4 x 10mm holes - maybe slightly bigger
Post 75x75 - drilled 11/12mm for the bolt to go through
Sunk into the post by about 25/30mm
The gate 1900mm high by 780mm wide is hanging off this post
thanks in advance for any suggestions
4 bolts used
