fixing into hollow brick wall
14 Sep 2009
Hi. What's the best way to make fixings into hollow bricks (the ones like air bricks)? I have a couple of wall brackets to put up to hold guitars - so not a huge weight but not something I would like to see fail. Some people suggest drilling then filling the hole with gripfill, putting in a wall plug, waiting for it to dry, then screwing in like normal. Does that work? Or is there a better method?
Ta!
Use the correct screw in plugs for the blocks and it will be fine.You need the spiral plugs with wings, prevent the plug rotating, other plugs just pull out.
Thanks. I am not sure what you mean by spiral plugs. The only spiral things I can seem to find in the likes of Screwfix are fixings for plasterboard.
They certainly look like airbricks - or at least the ones I saw coming out of next door when some internal walls were being taken down looked like them. Whether that's what they actually are, I don't know. An electrician complained about them when fitting some sockets elsewhere on the same wall (but to be fair to the bricks, he was useless). I think he referred to them as honeycomb bricks.
