Hi folks, just after some clarification, hope you can help..
I am installing a 1200x800 shower tray, into a corner, which will then have a small partition erected and a sliding door to complete the enclosure.
I intended to mortar the tray to a waterproofed ply floor (as per MI's), but compatibility problems mean the waste position must move, and the tray has to rise! No major drama, some timber supports, and more ply will effectively lift the original design by 80-90mm. I didn't fancy a riser kit, as little legs just don't inspire the same confidence as a bunch of 4x2 and a wooden board.
However - I spotted under the now incompatible tray, 7 circular recesses, looking suspiciously like they were intended for riser legs. This being the case, I wonder if the manufacturers generally recommend NO cement with riser legs? If the legs are fixed directly to the tray, and screwed to the floor, where would the mortar go? Also, is it actually solid enough?
Its an MX Elements, stone resin tray I will be buying (wide enough lip to take the door), and browsing their website seems to bear out what I have suggested i just wanted to check out the practicalities of using a riser, and whether it could actually save me some hassle?
Thanks.
Thanks.
