Need to fit a 1m x 2m splashback to a kitchen wall.. and need advice on adhesive selection... The supplier recommended Evostik Seriously tough, which I assume is similar to No More Nails.. and the like...
I did notice reading the back of a tube of NMN that you only have a small window within which to fix the materials together... so Ill need to apply it to the splashback, then mount it within 10 mins or so...
The kitchen wall which is painted, has some flaking paint... so Im sure I should get rid of any of this, or remove all the paint?? Ive also noticed some slightly hollow parts of the underlying plaster, so I dont know whether to remove this.. theres not much, so I was hoping the stanless steel would cover enough area not to have to bother removing it... or should I play it safe, and knock the blown plaster away... Id hate for the sheet to fall off the wall...
Any advice...
Any advice...
