I'm in the process of fitting a stair runner, waterfall style, and I've got a reasonable amount of tension (but probably not as much as a pro!), but I think it would look better if I could spot fix the carpet to the riser. I think it just needs 3 pins 2-3" above the tread, left middle and right of the runner to pull it into the riser a bit.
However, it's a loop pile, jute backed, wool carpet and I'm struggling to think of a suitable pin that won't be visible. Possibly staples would work, but I only have T50s in the right length, which are rather thick.
Possibly spray adhesive would work, but not sure if there would be good adhesion with the jute backing and could be messy and perhaps seems a bit "bodgy".
Thanks,
Lance
Thanks,
Lance
