I'm fixing a upvc window which is half height of door(brick left side) to a upvc door(brick right side) with concrete lintel above.
1.Does the window just have couple screws on left side into brickwork, or is it ok to screw up thru dpm into concrete lintel?
2.Was going to join the two simply with screws and cap with plastic trim edging-is this sufficient?.
3.Does the back edge of pvc frame run flush with back edge of external brick?
4.Can i get away with rockwool cavity batts or kingspan as a cavity closer?
5. Is it best to have the internal and external brickwork at the same height where the window will be?
