fixing wall plate andother questions
21 Sep 2010
Kent
I am in the process of re building part of a stable block as we are converting to a granny annexe. I am almost ready to fix the wall plate but want to check few things.
The wall is built with blocks ( solid no cavity ) and is 215mm wide do I follow the old part of the stable and just put up a 3inch by 4inch wall plate or do I span the wall 215mm ?
Next if I do just keep the 3X4 with this fixed on the outer part of the wall if I use straps is it ok to bend them again so a basic L shape strap then has an extra bend in it ?
do need to bolt the wall plate down also if so can someone recommend a product. e.g. drill , resin and bolt
lastly a question re joining the new part of the walls to old part. Building control said they should not be fixed directly but looking into this I cannot find product to do this is it just a sealant between the gap?
Sorry loads of questions I really appreciate all the help I get on the forum.
Cliff
Wall plate usually goes on the inner part of the wall, and is then tied down to the wall with long straps.
Don't see why building control insist that new and existing walls are separate?
Ours often insist that new wallls are bonded to existing or tied mechanically.
You can get starter strips with adjustable angles for building-in, but proper traditional bonding is better IMO.
