nice work, greeny4, but you won't get 10 pages from me.
Good luck, take care
John do really expect me to believe that that's a genuine misunderstanding? - go awayjohn1 said:IT IS NOT CLEAR THAT HE TOLD YOU TO TEST 'LIVE'
Sheds said:Hib said:wrote:
I never put an ohmmeter across anything, some others here seem intent on using the terms 'continuity tester' and 'ohmmeter' interchangably and thereby confuse the issue
FFS.
WHAT YOUR METER DOES ON EACH OF ITS SETTINGS AND HOW IT WORKS
Thanks to those who genuinely tried to help.
To those who didn't - get a life
Are you simply testing for live voltage throughout the appliance, from one point to another?
The only way to know exactly where the problem lies (should you wish to) is to post pictures of the tester, the site of the test and the device that tripped.
What, in your mind, makes you think it's OK for you to use your meter for, or on, anything whatsoever when you clearly have no idea what it does, or how?Because other people keep talking about an ohmmeter test rather than a continuity test - one of the 'terrifying' reasons given that i shouldn't test live is that it will give inaccurate results, which would not be an issue if we stuck to the facts - it's a continuity test - buzzer or no buzzer, on or off, black or white. There is no reading for the power to distort as with an ohmmeter test.
Hib said:Thanks to those who genuinely tried to help.
Fellas don't think i haven't noticed the attempt to avoid answering the question:
How does live continuity testing cause a 30 - 32 amp fuse to blow and a cooker to melt down?
As Spark123's, SecureSpark's and Mike's answers (among others) indicate - it doesn't
Don't bother reverse arguing by saying 'well it did, therefore it does'.
In theory, C-testing should not've caused the problem.
Someone explain from theory alone how C-testing caused the problem (without sidestepping the question by saying 'it could damage the meter' or 'it will give inaccurate results').
And to pre-empt the already used 'enlightened' subterfuge - "it could damage the components" - How could it damage the components? Assuming i didn't short anything by mistake - how could live continuity testing cause the problem?
John1 said:How about you explain, in theory, how it doesnt or shouldn't cause a problem????? If a 32Amp mcb triped then you, your probe, your meter or you spurs have shorted something out!
