    Dismiss Notice
Flat Roof Abutting to Pitched - how to join properly?
Discussion in 'Roofing and Guttering' started by NealHarman, 14 Sep 2005.
  1. NealHarman
    NealHarman
    6 Jan 2005
    59
    Thanks Received:
    2
    Country:
    Hi, I've got a flat roofed extension abutting a pitched (concrete tile) roof. The, er, "person" who built the flat roofed extension (no planning, no BC) just removed the bottom row of tiles and continued the flat roof under the tiled on. It doesn't leak (at least not there) but both have to come off (both in generally poor condition, flat intended to be used as a roof terrace but not nearly strong enough) and I'd like to do it properly. How should they be joined?
    And while I'm at it... I'm happy to replace the pitched roof, but have heard that flat is not DIY? Currently it's fibreglass and I'm assuming it's not a good idea to walk on regularly.
    Regards,
    Neal[/i]
    • Thanks Thanks x 1
  2. chappers
    chappers
    27 Aug 2004
    3,254
    Thanks Received:
    357
    Country:
    Providing the actual roof structure is strong enough to take the load then there is no reason why a fibreglass or polyroof shouldn't be walked on, it is much tougher than felt.
    Has your roof covering started to lift from the structure. how old is it because most fibre glass roofs are pretty good nowadays.
    Dressing the roof up under the tiles is the normal way to finish the roof.
  3. NealHarman
    NealHarman
    6 Jan 2005
    59
    Thanks Received:
    2
    Country:
    Thanks for the reply!
    The joists are only 4x2, and although not that big it's definitely a bit 'bouncy'. I could actually sort this from inside, and most of the fibreglass is OK, but there was absolutely no fall on it at all when built, and someone's built a set of concrete steps up to a large window for access. This has made it sag (and damaged the flashing) so you get a big pond and a leak when it rains - think I might as well start again as faff about trying to fix it.
    Something done properly then - the pitched roof is currently off, and the fibreglass roof continues up the rafters for about 20cm.
    Thanks again,
    Neal
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
