Flexi tap tails hand tight?
22 Mar 2021
Hello, I have purchased a mixer tap and the tails go up in to the tap body and I can only assume hand screw in? Does this sound correct? I've tried this but the base of the tap is now wet when connected so I can only assume its not fully sealed. Any advice appreciated.
Thank you
8 Mar 2009
Staffordshire
They only need to be hand tight because they seal on the O rings.
You must put a smear of silicone grease (or similar)on them before inserting them so that the seals don't get damaged.
Sounds like you've damaged them, you'll have to replace them.
27 May 2011
Also, be careful you're not undoing them when tightening up the other end.
