Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I've noticed one of the flexi tails on my new tap is loose where it fixes inside the tap body. Is there a special tool to tighen it? - it looks impossible to fit anything into the body of the tap.
Always best to tighten the tap tails well, then lower the whole affair through the sink hole, I find.....hopefully the 'o' rings are keeping things water tight for now?
John
Aaah right! If the tails are copper, then don't distort them with pliers, just nip them up.....if they are braided flexi, there's often some small spanner flats or failing that, use slip joint pliers.
I use a smear of Hylomar jointing compound on the 'o' rings for that belt and braces approach.
John
