Flexible Shower Pump Hoses
19 May 2006
Can anyone recommend a supplier of flexible hoses suitable for a shower pump.
I need 2 off 3/4" by 15 mm, and 2 off 3/4" by 22mm, but.....I could really do with elbows on the 3/4" fittings
Any tips gratefully received.
You could probably make the connections direct with plastic pipe since it will have enough give not to pick up the vibrations of the pump. What happened to the flexible hoses that came with the pump?
you won't get shower pump flexi hoses from any shed not with the angle connector.
