Just bought a mono basin mixer that comes with 2 x flexible tails.
I've screwed the tails into the mixer (M10 threaded) but the supply end is a 15mm screw fitting with a rubber washer inside. Is it ok to remove the nut and olive from a 15mm compression isolating valve and screw it directly to that or will it chew the washer?
