Flexible tap tails?
15 Dec 2009
Whitby N Yorks
I bought 2 cheap stainless steel taps off ebay for my boat and am looking to buy flexible tails. As it is not indicated on the box or in the ebay listing I am unsure what threads they are. The bore is about 16.5mm and the maximum diameter of the threads is a little under 20mm. I have looked up the spec for 1/2" bsp and understand the OD of the threads should be 20.9 mm.
I guess I have bought taps with an odd thread?
Are tails available for these taps?.
Additionally I will be fitting them to 15mm plastic pipe, what fitting do I need?
Advice most welcome
Mike
Can you post a photo of the tap and or underneath where connections are made?
Yes I probably can but will sort this today at Screwfix/builders merchant. I did see a video on youtube warning of purchasing cheap taps off ebay having non standard threads after I had bought them. Hoping they are are 1/2" bsp and I will use JG speedfit tails.
Will let you know how I get on.
Mike
