Hi. Would appreciate any ideas as to what fitting would help me position a back to wall WC to this soil pipe. I plan to put the loo and concealed cistern on the left hand wall but the partition will not be so deep as to connect the soil pipe horizontally. Ideally the exiting pipe would come in to the left of where it is but I can't get to it outside without breaking up concrete. It seems I need a flexible connector that turns three corners - is that possible? I'm concerned it would need to turn in the cavity and also the fall might be a problem. I also want to fit a sink to the same wall so need a waste water connection (boss fitting?). I know the easy thing would be to fit the loo to the other wall but it'd be too close to the window. Previously it was all under a raised platform which we'd like to avoid reinstating. Any links or suggestions would be appreciated. Thanks
View media item 87471
