- Joined
- 11 Jan 2009
- Messages
- 1,105
- Reaction score
- 6
- Country
Hi
Realise that I’m in danger of fanning flames, get spark, etc etc but here goes. Had to replace bulb that popped and defective dimmer (9.5 year-old son hammering it!). Gist is that in my haste I bought a brass one gang two way wall switch and 11W energy saving bulb from Homebase.
When I replaced the dimmer I tried to follow live, switched live wiring exactly (L1 into L1 and Com into Com etc). When I turned the power on nothing! I then switched the live wires and it worked except that the bulb flickers for a second when you switch off. Doesn't flicker afterwards or while on, literally just for a second as you switch off.
I’ve done some research and it’s evident that this happens sometimes. I’ll try the bulb somewhere else to confirm when I get home but is there a possibility that the flicker could be related to bad wiring on my part? Just concerned that I had to reverse what I thought was correct when wiring etc. Having said that maybe going from dimmer to two way was slightly different configuration.
Your advice would be much appreciated.
Longshanks
Longshanks
