Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Right, discovered 3 red wires going to the 2 MCB's and I have worked out 1 is the smoke alarms, 1 is upstairs lights and 1 is downstairs lights. I have tried all 3 one at once in the 1 working MCB and still can't get the downstairs lights to work so I am assuming it's not a fault in the CU.
The downstairs lights have the following on the circuit.
All bulbs are low energy
2 outside lights
1 hall light
3 living room lights
4 gu10 dining room
10 gu10 study
1 gu10 2nd hall light
1 bathroom gu10
12 gu10 kitchen
1 fancy bulb in kitchen
2 low power extractor fans
I had removed all bulbs but 1 but still intermittent.
The study was on a dimmer which I have removed and replaced with a standard switch.
Lucky you didn’t go and buy a new MCB then!
Do you have a two-probe voltage tester, or a multimeter?
If yes then you need to start at the consumer unit, check voltage is leaving from the MCB. Then you’ll need to work your way round each of the light fittings to find out where the fault might lie.
It may be obvious and common sense to you and me. But I was waving the caution flag to our friend, who may not be familiar with the insides of a consumer unit.
