Floating insulation for UFH on suspended floor...but not between joists!
29 May 2011
Dorset
Hello All,
Has anyone advise or experience on the following...
I'm looking to lay slab insulation on top of an existing suspended floor (ground floor & well ventilated) as a floating floor and then top it with Engineered top boards. Floor height is not a problem and it seems easier to do.
Then the idea of installing UFH has developed and I need to know if it's OK to buy some kind of pre-routed insulation slabs designed for UFH and use them, instead of the standard celotex / kingspan type, then lay in the UFH system...topping it all off with Engineered flooring.
Hello,
I'm looking for some thick insulation panels for UFH pipe, preferably thicker than 25mm, and the only things I can find are Polystyrene (EPS) which I understand isn't as efficient as PIR boards...any ideas?
I thought wet underfloor heating was designed so the pipes heated up the screed that was poured over them, and the screed retained the heat.
I understand that there are a number of ways and using screed is one of them, however, you can also lay certain floor coverings (19mm Engineered board in my case) directly onto UFH pipes inserted into 'spreader' panels, without any other intermediate substrate between them.
Does anyone have experience of this?
