    Dismiss Notice
Flood light wiring
Discussion in 'Electrics UK' started by Snowyy, 24 Jul 2021.
  1. Snowyy
    Snowyy
    4 Sep 2013
    113
    Thanks Received:
    Nottinghamshire
    Country:
    Hi
    Looking at replacing my floodlight with intergrated pir with a separate light and separate pir that will be located around the corner from the light. I also want to add an additional light with an intergrated pir to the same circuit and would like both lights to come on when either of the pirs are activated. The current light is run of a plug from the inside of the house, I have an idea of how to wire these but want to make sure it is correct. Figured it was supply to pir, then n, sl and e from pir to light. Also n, l and e from pir to light with pir. Then sl from light to sl to light with pir, resulting in light with pir having power and triggering the other light when motion detected and pir having power which switches light on and triggers the other unit when motion detected. Hope I’ve got that correct.
  2. Sponsored Links
  3. ericmark
    ericmark
    27 Jan 2008
    18,618
    Thanks Received:
    1,746
    Llanfair Caereinion, Nr Welshpool
    Country:
    Some PIR's will work in parallel others will not, so you need to read the instructions. Personally I intend to move to internet devices and app on phone, I see no point in helping an intruder by lighting their way, and find the lights going out as PIR has not detected me dangerous.
  4. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,553
    Thanks Received:
    2,132
    Oxfordshire
    Country:
    The basic problem with your plan is that many of today’s integrated floodlight+PIR products do not provide support for switching or being switched by external devices. Most of them only have L&N terminals. The SL connection being buried inside the guts.
    There may be some out there, but you’ll find information thin on the ground. Also, as Ericnark says, they often cannot work in parallel with other devices.
    IMO, the reliable way is to abandon the integrated FLOOD+PIR approach, but use standard floods and as many separate PIRs that you think you need. Then you can arrange a variety of switching options.
    • Like Like x 2
  5. bernardgreen
    bernardgreen
    3 Nov 2006
    25,830
    Thanks Received:
    2,572
    Bedfordshire
    Country:
    Taylor has given the best advice.
    • Thanks Thanks x 1
    • Like Like x 1
  6. FrodoOne
    FrodoOne
    20 Feb 2017
    513
    Thanks Received:
    52
    Melbourne, Australia
    Country:
    Australia
    I agree with both of the above
    BUT
    I wish to add the following: -
    When one installs multiple PIRs to control any circuit it is a "good idea" to install, between each of the "control" wires of those PIRs and the "load", a Connect/Disconnect switch, so that each individual PIR can be used to control the Light Fitting (Luminaire) concerned and whatever is happening to the other PIRs does not interfere with any such setting of an individual PIR.
    Yes. This IS an additional cost and initial inconvenience.
    However, it makes setting up the sensitivities of each PIRs much easier and, when one of them fails (as they will), it makes determining which one it is much easier.
    Plan ahead !!!!
    • Like Like x 2
  7. sparkymarka
    sparkymarka
    16 Feb 2011
    8,910
    Thanks Received:
    1,351
    Sheffield
    Country:
    Or fit a proper lighting system that will last far longer that the cheap tat ….EG….GJD lighting system …
  8. Sponsored Links
Loading...
Share This Page
