Hi
Looking at replacing my floodlight with intergrated pir with a separate light and separate pir that will be located around the corner from the light. I also want to add an additional light with an intergrated pir to the same circuit and would like both lights to come on when either of the pirs are activated. The current light is run of a plug from the inside of the house, I have an idea of how to wire these but want to make sure it is correct. Figured it was supply to pir, then n, sl and e from pir to light. Also n, l and e from pir to light with pir. Then sl from light to sl to light with pir, resulting in light with pir having power and triggering the other light when motion detected and pir having power which switches light on and triggers the other unit when motion detected. Hope I’ve got that correct.
