Flooded footings
12 Jul 2008
Wiltshire
Ive dug 200mm down for my patio base and water is building up on the clay and as you can imagine so areas and very boggy. Can I still fill it with my 100mm of scalpings or does it need to dry out first?
It needs to dry out a bit, the vibrating plate will not move forward and will just sit there gradually sinking on very wet sub-base
I've bailed the water out from 2 separate puddles. The ground is now just very squelchy underfoot. Is this ok to fill with sub base or do I need to leave it still?
if its heavy clay i would leave it a while to dry out, the plate would just ram the type 1 into the clay making a horrible mess.
Its a ballache i'm sure if your all ready to go but i would wait for at least 1 good dry day then make a start the next.
You could use a geotextile under the type 1 to stop it and the clay mixing.
