Looking to install Warm Water Underfloor heating to the ground floor of my house. i currently have 22mm oak flooring throughout the ground floor. The plan is to lift the oak flooring then lay 20mm x 50mm batterns on the floor at 400mm centers. Then lay a layer of plywood/Chip board preferably 10mm to keep floor build up as little as possible then relay the 22mm oak flooring to the living room area. Is This all Possible or is 10mm plywood not sufficient in strength? Now the tricky part. in the kitchen iam using the same method batterns....10mm ply.....but the finnish floor will be ceramic tile instead of oak flooring is this possible?
Any help on this one would be greatly appreciated guys
Cheers
Kris.......
Cheers
Kris.......
