Hi there, I have had some building work done so that now I have some wooden floors and some concrete, all butting up to each other.
I want to lay ceramic/stone in some places, in others I want to lay laminate/hardwood floors.
What prep is required in both cases? I read on here that for laying wood I will need to lay boards down on the floorboards and concrete first so that the absorbency is even throughout. that makes sense, what would i use, would it be 4mm weather board ply? How do I fix it to the concrete?
With tiling presumably I'll end up doing the same as otherwise the levels will be all wrong.
Many thanks.
Many thanks.
