I have been considering flooring my downstairs in engineered wood. However, my neighbour just has bare floorboards. The floorboards are quite nice.
3 questions on this if anyone can help?:
1. Where the old faux fireplace is, the boards are very dark - presume this is where the mortar or adhesive has discoloured the wood. I presume sanding it hard will get the old colour back? Or will I need to replace with new boards?
2. The boards are pretty much flat all over except for one ridge which appears to be one joist which is a bit higher. The chimney breast skirting is about one inch high one side then the floor slopes both ways down to the same level from this. I presume just hammer the nails in and sand it till it looks more level?
3. the house has BIG crawl space. About 6 foot one end and about 2 foot the other (built on a hill)
The textbook says always insulate the ground floor but my neighbour says it’s not too cold and that because the crawl space is very large it’s unnecessary. Thoughts on this?
many thanks. We want hard floors but I can save several thousands by using the boards.
insulating under worries me as it’s a building regs job and quite a challenge for a novice as I’m aware it needs to be perfect otherwise you get damp issues.
thanks
thanks
