Flow meters all at zero on Uponor Vario S UFH manifold.
13 Oct 2010
Norfolk
The manifold is a 3 loop Uponor Vario S.
I have just installed 3 new flow meters and Pin return valves.
I flushed and filled each loop one at a time, but the flow meters all show the red disc at zero. The water in the glass tubes all sit at around 2.
The return pipes are 1 x warm 2 x coldish.
Thanks in advance for any help.
Are the flowmeters of the correct type, ie, the same as the old ones, depending on whether the top or bottom manifold is the hot one.
You said that the water in the glass tubes all sit at around 2, that looks like air locking?
Can you remove one of the heads and push? the pin down to see if you get a flow with a UFH demand
Is there a mixing manifold pump?, (photo)
Today I will flush and refill then get back to you. There is no mixing pump and the manifolds dont have a an air vent. Hot water is supplied by a HeatRea Sadia and is pumped by a water pump. Thanks Johntheo5.
Is there any means of venting the manifolds at the opposite ends to the pipe connections?, maybe worth installing some form of vent if these ends are just plugged.
Its a ABV, a automatic bypass, probably used as a balancing valve, seems to be set to quite high (can you read the index on the side) but won't get rid of any air.
I shut down all loops ( Flow meter and pin valve) apart from number one. Waited for a steady flow of water then shut down that loop and opened the second loop and so on.
Hose pipe in the top from tap - drain from bottom into bucket.
as per this .
  • uponor-installation-manual-Vario-S-manifold-FM-INT-1087620-201905.pdf
So no air bleeds at the top of the valves Like on the top of these? Can you take a pic of the manifold a little further out please?
