Hi there,
Got my Vaillant boiler pack from Mr Central heating today. They left the standard horizontal flue kit in the pack even though I ordered a vertical flue kit to pop out of the flat roof above the boiler.
Anyway - I realised today that unfortunately, where my vertical flue wants to go straight up and out of the flat roof, it will interfere with the eave of a section of pitched roof that overhangs onto this flat roof by about 3". Bugger!
I could hack the eave about a bit but that could be a bit messy in terms of waterproofing. I could also space the boiler about 3" off the wall i'm putting it on and the flue would go up and out without fouling the eave, but that seems a bit of a bodge too as it will make the pipework under the boiler a bit messy as it all doglegs back to the wall.
Since i've got the un-needed horizontal flue kit, I've already got a 90 degree elbow. If I get another one I could put the two together to create a 'dogleg' then put the vertical flue on that. That would mean the boiler can go where it wants to, and the vertical flue will miss the eave.
Question is, is that OK? I've seen using a pair of 45s with some straight between to achieve a similar goal externally, but since I've already got one 90 I thought I could use that and get another. Also I'm not sure i'f i've got the space between the boiler and the roof for a pair of 45s with some straight between.
Last question - my boiler is a vaillant ecotec pro but the vertical flue kit they have supplied appears to be glow-worm. It's identical to the vaillant bits though and goes together fine. I assume it's OK to mix manufacturers flue bits if they are compatible?
All help appreciated. Cheers,
Liam
Liam
