Had a look around the forums and Wiki but can't seem to find an answer to this...
I've moved house and the bathroom has a dimmer controlling several halogen downlighters. There is also a mirror with fluorescent lights in it and its own light switch. When the main lights are on you can't operate the lighted mirror as the fluoro tubes flicker very dimly; if the main lights are off then the illuminated mirror operates ok. I checked out the wiring in the loft and the mirror power has been taken from the same spur as the one that powers the dimmable halogens, presumably this is what is causing the problem with the dimmer affecting the fluorescent tubes.
My question is - can I isolate the fluorescent tubes in the mirror from the effects of the dimmer switch? If so, how?
I also want to put in an extractor fan in place of one of the lights directly above the shower unit but from what I've read in the threads I'd need a separate circuit?
