Fluorescent Light not truing on?
19 Feb 2005
Yesterday in my kitchen the 6ft Fluorescent Light want off and I thought it was the Fluorescent tube or starter so I changed theme both but still not coming on its not flickering either. Thanks
You are going to need a multimeter or a proper voltage indicator (NOT a neon screwdriver).
Take the cover off the fitting and check if there is 230 volts at the power input connector.
If there is then there is something wrong with the fitting
If there is no power then there is a fault with the switch or the wiring - a much bigger problem!
